be_zwe
Nov 04, 2016Aspirant
How can I make the parental control filter work separately on different devices?
Hi Everyone! I had tried looking for an answer prior to posting this question. If I missed something, by all means you can point me to the right direction. I would like to limit my son from ...
- Nov 28, 2016
Hi DexterJB,
Thank you so much for all the help. I found the solution to the problem!
I found out that not ALL categories under the "High Filter" are being blocked. Exactly the main reason why my son could still access the internet. Therefore, I chose the "Custom Filter" and checked every single one of them. Whoala!
Again, thanks!
Br,
B
DexterJB
Nov 22, 2016NETGEAR Moderator
Hi @be_zwe,
If you want to block your son's Internet access on a specific schedule you can do Address Reservation for his device/s and set a specific range of IP then block all services on a set schedule. You may find the links below helpful.
http://kb.netgear.com/app/answers/detail/a_id/24091
http://kb.netgear.com/app/answers/detail/a_id/24054
http://kb.netgear.com/app/answers/detail/a_id/24055
Dexter
Community Team
be_zwe
Nov 28, 2016Aspirant
Hi DexterJB,
Again, thanks!
Br,
B
