drgscott
Sep 24, 2016Follower
How can I SECURELY change my admin pw for r7000 router
I want to change my admin pw and therefore have to go to Netgear's site (I understand the admin name itself cannot be changed). A dialogue box pops up for user/pw, but with warning that the site is ...
microchip8
Sep 24, 2016Master
that "netgear site" is actually a domain that points to your router, so you won't have to type 192.168.1.1
michaelkenward
Sep 25, 2016Guru - Experienced User
Like microchip8 said, there is no "Netgear site" involved in this.
What you are doing is using a short cut that, as microchip8 said, bypasses the need to type stuff like 192.168.0.1 or 192.168.1.1 into your browser. (Netgear has used both in the past.)
Those are addresses for the router on your local network. They'll work even if you unplug the Internet.
Using www.routerlogin.net just makes it easier.
The manual explains how to do what you want. Get it here:
R7000 | Product | Support | NETGEAR
Look on page 147.
Oh, and do not confuse the router's password with the wifi passwords. They are not the same thing.
