leonoos
Jan 10, 2016Aspirant
How do I change to 802.11g from 802.11n, i have a device requiring the 802.11g
TheEther
Jan 10, 2016Guru
What is model of your router?
With modern routers, you should not need to change anything. Routers should, by default, be backwards compatible with 802.11g. Older routers may have a N-only Wi-Fi setting that you would need to change.
