Ghurxa
Jul 04, 2016Aspirant
How do I use the QoS in WNR2000v5
I'm trying to set up my laptop in genie to have it set set to the highest priority, but they're all set to normal and i don't know how to change that. Any suggestions? Much appreciated. (:
- GhurxaJul 05, 2016Aspirant
Priority stays as normal when i change it. I click the bubble, set priority to highest, then click apply. When it's done, it stays the same. Doesn't change.
I believe i got it. Under the mac device list, it says normal still, but under QoS rules it is under "highest".
- TheEtherJul 05, 2016Guru
You're good. The fields under MAC device list are used to add a new rule.
