Soheils's avatar
Soheils
How do you set bypass ao Tivo?
I have a bypass account set on my Router and want this to be on my Tivo and LG Smart TV. I try to set it using the Genie App (Android) or my PC and in both cases it says I have to put the Genie app on the devices which I can't. Any ideas on how this is possible?
1 Reply
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi Soheils,
    You can only use the the bypass login on devices where you can install the Genie app/program which is only available on Android, iOS, Mac, and Windows. However, you can set the filtering level to "None" on those devices using the per device filtering feature. You can check the link below.
    http://kb.netgear.com/app/answers/detail/a_id/29913
    Dexter
    Community Team
