mrekimf
Apr 01, 2016Apprentice
How to access ready share USB storage on cell phone away from home?
How do I access ready share usb storage device away from home on my android phone. I know you can access it on laptop through the web address www.readycloud.netgear.com
But this dont work for cell phone.
Hi there; to view your usb files via your smartphone you will need to download the netgear readycloud app that is availbalbe for ios and android devices. I use it on my iphone and it works just fine... hope that helps.....
I forgot to add that you will first have to create a ready cloud account......to do this you have to go into your router's settings and under admin go to usb then look for the ready cloud tab and follow the directions for setting it up......once you get that set up, download the ready cloud app to your smartphone and use the login information that you created for your ready cloud account....
