JTrumm
Mar 10, 2025Follower
How to change security setting on R7000p?
I need help to change the security setting on a R7000P router. I downloaded a new version of the Nighthawk App on my iphone 13. I thought I could change the setting in that app but I don't see how to...
michaelkenward
Mar 11, 2025Guru - Experienced User
Which security setting? WiFi?
Why do upoou need to change it?
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Specify Basic WiFi Settings.
You may have done that already. I can't tell from your message.
Just another user with time on their hands.
