Retired_Member
Sep 24, 2021how to delete netgear account?
I want you to delete my account It seems netgear is not allowing users to delete the account once opened up. And need to contact on this forum to delete the account. No way to contact support wit...
- Retired_MemberSep 29, 2021
michaelkenward
Sep 26, 2021Guru - Experienced User
This place is mostly a user-to-user community. We can't do much to help.
You'll have to invoke divine intervention in the shape of a Netgear moderator.
Blanca_O, ChristineT or DexterJB maybe able to help.
For some reason known only to Netgear, it removed the "get me out if here" option some time ago.
It might help if you told them which "account" you want removed.
Retired_Member
Sep 29, 2021michaelkenwardThanks for invovlving other users.
I have seen numerous post about deleting account so thought I would ask here as Netgear doesn't have any way to delete account from UI itself and it is more cubersome to go through long ordeal to delete (and first find how to delete the account) (I can easily see one of the dark patterns followed here by Netgear so that users cannot delete account easily.)
