Keeper7399
Mar 21, 2017Guide
How to easily block a device from the network
Okay, there has to be away to kick a known device off your network.I need to block my son's laptop from the internet as form of punishment. I know which device is his, there has to be away to revoke ...
michaelkenward
Mar 22, 2017Guru - Experienced User
What Netgear hardware do you have?
Keeper7399
Mar 22, 2017Guide
router R6300v2 firmware V1.0.4.8_10.0.77. I dont see how that matters...i should be able to turn off and turn on what and who is connected to my network right?
- michaelkenwardMar 22, 2017Guru - Experienced User
Different devices have different features. That's why they cost more.
It also helps to find the manual:
>>> R6300v2 | Product | Support | NETGEAR <<<
How is this miscreant connecting to the network? Wireless? Wired?
If it is wireless, then it may be easier to set up a list of people who can access the network.
See page 99 of the manual. Just add the people you trust.
- Keeper7399Mar 22, 2017Guide
there are only 7 devices that have my passkey, every device is connected wirelessly. Im sorry its just frustrating because if we all netgenie and a network map we should be able to easily kick someone from the network using the security features of the app or from the network map from the main computer. I am looking for temp solution so that I dont have to physically take the computer away.
Change the password and keep it to yourself.
