gayam007's avatar
gayam007
Follower
Oct 27, 2019
how to increase r6120 speed
my internet connection speed is 200mbps - but router limits the speed to 100mbps speeds mention on product is • AC1200 WiFi—300+900Mbps† how can i see 200mbps on my system using ethernet ?
  • schumaku's avatar
    Oct 27, 2019
    You can't, the R6120 is designed to run on slower Internet connections.
    The R6120 Data Sheet and certainly the associated documentation does show that the WAN/Internet port as well as all LAN ports are Fast Ethernet standard, so max. 100 Mb/s only to the Internet (limited by the WAN port).
    • Five (5) 10/100Mbps (1 WAN and 4 LAN)
    Fast Ethernet ports with auto-sensing technology
    These are the theoretical max link rates of the 2.4 and 5 GHz WiFi - the available net bandwidth can be shared on the same WiFi with multiple LAN and Internet port only
