bfcx05
Mar 13, 2017Aspirant
how to manager 6300v2 via TR069
I want to manager NetGear device via TR069,but i can't find the TR069 client to set the ACS URL. Firmware Version:V1.0.3.22_10.0.67
Mar 14, 2017Guru - Experienced User
I'm not seeing TR069 support claimed in the user manual or the product data sheet. Are you sure it supports it?
https://www.netgear.com/support/product/R6300v2?cid=wmt_netgear_organic#docs
bfcx05
Mar 14, 2017Aspirant
yes,i have two 6300v2.I can configure the TR069 for one,but the other could not.
There is another question about upgrade,trying to upgrade the "issued" ont to the build that the same as the other 6300v2 that woked fine,but failed with below print:
"This firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product."
