Ikram786's avatar
Ikram786
Follower
Jul 13, 2019
how to recover the router login password?
1 Reply
  • michaelkenward's avatar
    michaelkenward
    You have a few options:
    • see if the default password (on the device's label) still works
    • dig deeper into your memory
    • use password recovery, if you have set it up
    • reset the thing to get back to the defaults
    There is support for the R6120, including a manual, somewhere at the end of this link:
    >>>> R6120 | Product | Support | NETGEAR <<<<
    Check the sections Set Up Password Recovery and Factory Settings.
