mordinir
Jul 27, 2021Follower
How to reset seciruty questions on netgear genie
I am trying to reset the seciruty question to reset the password , any way of doing that? thanks
Jul 27, 2021Guru - Experienced User
If you can log into the device you can change them.
If you're unable to log in, then you'd need to factory reset to get back to defaults to set them up again.
to reset, push and hold reset for 7-15 seconds while powered on. then reinstall the device.
