TommyHuang
Jun 03, 2017Follower
How to set Ipv6 (Tunnel 6 in 4) on R6300v2 & R8000 ?
HI, All
First, I created regular Tunnel by TunnelBorker. Then want to set the Tunnel 6 in 4 to NetGear R6300v2 or R8000
Then want to set the Tunnel 6 in 4 to NetGear R6300v2 or R8000.
After testing ( www.ipv6-test.com ), the "IPv6 Connectivity" status should be -->
- Ipv6= Supported
- Address= xxxx:xxxx:xxxx:xxxx:xxxx:xxxx:xxxx:xxxx
- Type= Native IPv6
- SLAAC=No
- ICMP= Reachable
How to config it ? Or Netgear Wireless AP do not support ? Why not ?
1 Reply
Sort By
- William10aMaster
TommyHuang wrote:HI, All
- Ipv6= Supported
- Type= Native IPv6
- SLAAC=No
- ICMP= Reachable
If you are talking about netgears access point settings the dhcp assignment is turn off and handed off to the main router the access point only extends the router coverage area.
