Ntgrwifi
Dec 21, 2018Aspirant
How to setup Netgear a Wireless Router?
Hi,
I am a new user in this forum. And I want to know about netgear router login and about setup process. Can anyone help me?
michaelkenward
Dec 21, 2018Guru - Experienced User
The best thing to do would be to read the manual and the quick start guide for your router.
If you don't have one, then any router would do. They are all very similar in how they work.
I wonder, though, if the link you have is some sort of clickbait.
Ntgrwifi
Dec 24, 2018Aspirant
Thanks for your reply and suggest me.
