cyberbiker
May 26, 2023Guide
How to Turn Off Anywhere Access Using Routerlogin.net?
I am trying to turn off Anywhere Access on my RAX50. My iPhone is connected to it by WiFi. In the Nighthawk app it tells me I must connect locally to turn Anywhere Access off. How do I connect loca...
- May 28, 2023Kitsap, unfortunately, the R9000 and the RAX50 are different. You probably saw the screenshots I posted in DSL reports with the error messages. As soon as I go to Settings-Anywhere Access and then try to turn off the toggle switch for Anywhere Access, the error message pops up. There are no hot links anywhere else on the page associated with the lines or elsewhere on the page.
I’ll try to send a message to support@netgear.com with the link to this thread. Netgear hasn’t provided specific written guidance for the Anywgere Access feature for the RAX50 in the user manual or elsewhere on the Support site. The info available applies to several models, but it doesn’t work for the RAX50. I seem to be up the creek without a paddle.
Thanks for your efforts. If I find a solution, I’ll post it in this thread.
Kitsap
May 27, 2023Master
Attempting to configure, troubleshoot, or manage a router via an application on a mobile device is a folly at best. Otherwise you end up just where you are at.
Two other options. Turn off the application on your phone and attempt to connect through a web browser on your phone.
The other option is to borrow a real computer or invite a friend over with a real computer and connect through a web browser over the Wi-Fi.
cyberbiker
May 27, 2023Guide
I’ve tried to find Anywhere Access or Remote Management in routerlogin without the Nighthawk installed on the iPhone at all. They don’t seem to exist for the RAX50 remotelogin version.
I’d be curious to see if someone else with an iPhone and the nighthawk app can actually turn anywhere access on and off or whether they get the same error. I do have a laptop, I just haven’t used it in several months. I stop carrying it when traveling and can do virtually everything I need with the iPhone. I’ll try a laptop, tablet, and android phones are safe and the nighthawk app will permit Anywhere Access to be disengaged.
- michaelkenwardMay 27, 2023Guru - Experienced User
cyberbiker wrote:
I’ve tried to find Anywhere Access or Remote Management in routerlogin without the Nighthawk installed on the iPhone at all. They don’t seem to exist for the RAX50 remotelogin version.Remote Management and Anywhere Access are different things.
Anywhere Access is enabled by default. Unfortunately, while Kitsap is right to advise you that that mobile app is not always the best way to manage your router, in the case of Anywhere Access that's the only option.
Why are you trying to disable Anywhere Access?
- KitsapMay 27, 2023Master
The question in the original post, Is there a way to turn Anywhere Access off using routerlogin.net? The answer is no.
Like michaelkenward says, Anywhere Access is a creature of the mobile application and the mobile application only. (I am currently using Android V 2.26.0.2884)
From the opening page of the Nighthawk Application, go to the menu in the upper left corner. Tap and the menu page shows connected via Anywhere Access. Tap on the bar where it indicates connected via Anywhere Access. The page that comes up shows a local connection is available on one option and that I am connected via Anywhere Access with the check mark. Tap on the bar that indicates a local connection is available and the connection will switch, the screen will refresh. The menu page now shows my R9000 is connected locally. To switch back to being connected via Anywhere Access, close the application and restart.
To turn off Anywhere Access, use the process above to connect locally. Go to the menu in the upper left corner, tap on Settings, and on the next page an Anywhere Access option shows. Tap on the option and you will have a toggle switch to turn off Anywhere Access.
A series of screen shots is attached in a multi-page PDF file.
I normally find very little use for Anywhere Access and leave it disabled.
- cyberbikerMay 29, 2023GuideSOLVED IN MESSAGE 9 OF THIS THREAD (I see how to give it kudos, but can’t see how to mark it as the solution).
stated in Message 9 of this thread —
“From the opening page of the Nighthawk Application, go to the menu in the upper left corner. Tap and the menu page shows connected via Anywhere Access. Tap on the bar where it indicates connected via Anywhere Access. The page that comes up shows a local connection is available on one option and that I am connected via Anywhere Access with the check mark. Tap on the bar that indicates a local connection is available and the connection will switch, the screen will refresh. The menu page now shows my R9000 is connected locally. To switch back to being connected via Anywhere Access, close the application and restart.
A series of screen shots is attached in a multi-page PDF file.“
That worked Thanks, Kitsap.
Problem solved. My RAX50 is now connected locally each time I open it.
- cyberbikerMay 28, 2023Guide<< why="" are="" you="" trying="" to="" disable="" anywhere="" access="">>
Michael, I want to use the Traffic Meter feature. When I go to Nighthawk App>Traffic Meter and attempt to turn on the toggle, An error box (left frame in pic) says:
“This operation is not available using Anywhere Access.”
When I then go to l Nighthawk App>Settings>Anywhere Access and attempt to turn off the toggle, an error box (right frame) says:
“Anywhere access can not be turned off while you're connected remotely. Please connect locally to turn this feature off.”
I posted a screenshot of those error messages in dslreports.com at https://www.dslreports.com/forum/r33679511-Why-Does-RAX50-Think-My-iPhone-Is-Remotely-Instead-of-Locally-Connected since we can’t post screenshots here.
It appears there’s not a way to switch to a local connection with the RAX50 once it is already set up. However, I’ve seen no information that indicates I can turn the feature off during initial setup, if I was to reset the router and start again. - cyberbikerMay 28, 2023GuideKitsap, unfortunately, the R9000 and the RAX50 are different. You probably saw the screenshots I posted in DSL reports with the error messages. As soon as I go to Settings-Anywhere Access and then try to turn off the toggle switch for Anywhere Access, the error message pops up. There are no hot links anywhere else on the page associated with the lines or elsewhere on the page.
Thanks for your efforts. If I find a solution, I’ll post it in this thread.- KitsapMay 28, 2023Master
Thanks for your efforts. If I find a solution, I’ll post it in this thread.Not clear from your response. The error messages you are getting are expected as long as you are connected via Anywhere Access. Suggest you re-read my post above where I describe how to switch from the Anywhere Access connection to a local connection.
The differences you are coming up with are most likely due to you using the iOS application versus the Android application.
