BobCon
May 29, 2017Aspirant
HP Deskjet 3054 printer will not connect to Netgear router R6220
Push button set up times out. Wireless light on printer shows available and blinks blue but times out every time.
William10a
May 29, 2017Master
Have you tried to manually enter the ssid and passphase of the your network in the printer and not use wps?
- BobConMay 29, 2017Aspirant
how do I manually enter the SSID and password into the printer?
- William10aMay 29, 2017Master
Here is the manual for your printer you will need a usb cable to first connect the printer to a computer but make wifi enable all in the manual
