BobCon
May 29, 2017Aspirant
HP Deskjet 3054 printer will not connect to Netgear router R6220
Push button set up times out. Wireless light on printer shows available and blinks blue but times out every time.
William10a
May 29, 2017Master
Here is the manual for your printer you will need a usb cable to first connect the printer to a computer but make wifi enable all in the manual
BobCon
May 30, 2017Aspirant
I'm running OS Sierra 10.12.5. The print driver is 2.8.0 I've followed the manual instructions but still can't connect the printer.
- William10aMay 30, 2017Master
Did you use the same old ssid and passphrase if so the printer should have seen the network?
Here is the Apple setup page for your os https://support.hp.com/us-en/document/c04473034
- BobConMay 30, 2017Aspirant
I did use the same SSID and password as the old router. I've downloaded the latest print driver. I ran a Wireless Network test report.
It says, " Your HP printer cannot find your access point. Check that your access point is powered on (it is), Check that your HP Printer network name (SSID) matches your access point network name (SSID) excatly." Under diagnostics Summary it says "network name (SSID) found - FAIL.
Any help is appreciated.
