Jtw13
Oct 06, 2020Aspirant
I cannot for the life of me get into my netgear APP
I got a new phone and I have EVERYTHING turned on as far as push notifications and I attempted to get into the app to check everything out but the app has the two step verify method. I put in the pas...
Jtw13
Oct 07, 2020Aspirant
bump
Jtw13
bump
- schumakuOct 09, 2020Guru - Experienced User
Chicken and egg problem. You can't make a new phone trusted by using a 2FA method supposedly by receiving push messages. Allowing this would kill the advantage of 2FA. The push messages would go to your old phone. You can try to bring up your old phone by WiFi only...
Beyond, I'm honestly a little bit lost because of Netgear has removed the ability to change the 2FA SMS number from the Netgear Account Profile Login Settings.
Further on, even if Netgear does allow it: It's a litle bit blue eyed using 2FA based on Push only - which can go to a specific device only. The device can fail, can be lost, ...
On some Apps like Insight Netgear does offer using email for the 2FA part (beyond of push and SMS) - this might help, permitting not everything is bound to a single email without any other liked accounts where a friend or trustee can help to regain the access in case.
This used to be the workaround for changing the 2FA primary SMS number: ... to my knowledge but there was never one for push-only:
Login your MyNetgear account.
Go to Manage Profile.
Login Settings.
Two Step Verification.
Add your new SMS Text number.
Then you delete old and make your new Text primary.
===This is not available currently why ever.
Update: Instead sending a Push - isn't there an option for "Try different way" and select email for sending the code?
- Jtw13Oct 10, 2020Aspirant
There is that option but it's a two phase verification... so you need an email code plus the push notification.
Yep, I was hoping I wouldn't get this response but it's true. I sold the phone... I installed my old SIM card and that didn't even working. I thought I was clever trying that but no dice.
- Jtw13Oct 12, 2020Aspirant
Bump
Anyone else have ideas?
