Happymag
Nov 16, 2017Aspirant
My smart tv can see the network and it seems to be all set up on that end but it won’t connect with the router. Any suggestions or ideas to try??
michaelkenward
Nov 17, 2017Guru - Experienced User
Despite the name, Smart TVs are amazingly dumb. Problems getting them to connect nearly always come done to the TV. The router spits out its wifi, and it is then down to the TV to play ball.
Which TV is this?
Do other wifi clients connect as expected?
