Slr8929
Feb 01, 2022Aspirant
I have a C700v2 need help with app
On the nighthawk app when I go to devices each device has a link rate what does that mean? Is that the wifi speed that they are receiving from the router?
Feb 02, 2022Guru - Experienced User
That's their negotiated link rate between router-----device. It can change based on distance/interference.
And it gives you a rough idea of how fast the connection is because usually actual throughput speed is roughly 55-65% of link speed.
