Dabcounty
Nov 29, 2024Aspirant
I have a R7960P with issues
I can’t get my R7960P online in the app but it is working in my living room connected to mesh mr60 router I can only access the mr60 in app but shows my R7 is disconnected. Anyone know how to fi...
Nov 29, 2024Guru - Experienced User
Not sure if the NH app works like that, having two same Nighthawk systems online at the same time.
Does the R7960P work with the app if you replace the MR60 with the R series router? I should.
Dabcounty
How would I replace ?
- FURRYe38Nov 29, 2024Guru - Experienced User
Swap in the R series router for the MR. However I presume you may have replaced the R series router with the MR and MS MESH system already?
Are you using the R series router as a 2ndary wifi AP? This may not be needed.
