Nickevanss
Dec 06, 2022Aspirant
I haven’t been able to log into my NIGHTHAWK app since i first set everything up
I haven’t been able to log into my NIGHTHAWK app since i first set everything up, (2 years ago) due to the Logging in issues. I have a CM1100 Cable Modem and a AC2000 Smart Wi-Fi Router. I’m not sure...
michaelkenward
Dec 11, 2022Guru - Experienced User
What login issues?
What happens when you try?
Can you login using the browser route?
How do I log in to my NETGEAR wireless router? | Answer | NETGEAR Support
The best way in is with a wired connection to the router, but you can also use the browser on a wifi device that is connected to the wifi from the router.
It might be a good idea to check that this option works before spending too much effort troubleshooting the app as a way in.
