nicepls
Nov 14, 2016Aspirant
i want use another router as access point for netgear d1500
i mean
i want use netgear as my basic router
the older one tplink as access point
will they be same net name and password or different ?
Sort By
- Retired_Member
This should answer your question.. If after reading, you still have a question reply with it.
http://www.practicallynetworked.com/networking/convert_wifi_router_to_access_point.htm
- niceplsAspirant
thank u
just i have one Q to u
if i used the secondary router "older one"
will the signal of first router "netgear " signal improve ?? or an another separate network will be found if i used second router
i hope u understand me
- Retired_Member
you're Welcome,
read the article .......yes and No depending on how you set it up
