eaglepi
Jun 08, 2017Guide
I would appreciate some help to make sure that I have the proper security settings on my router
Hello, I currently have the NETGEAR AC1750 Dual Band WiFi Gigabit Router, when I originally bought it I set it up according to the instructions but now I'm wondering if I set it up properly. Course...
TheEther
Jun 08, 2017Guru
Yes, WPA2-PSK [AES] is the most secure setting.
eaglepi
Jun 08, 2017Guide
Something isn't right I have poor wireless when I am standing right by the router, this is a bit of a different question but still about Genie.
My 2.4 GHz and my 5 GHz say they are configured and they are active. I just wonder if I have my settings correct? Would somebody be able tell me what the settings for each section should be on my wireless for my 2.4 GHz and my 5 GHz, I can understand why I'm getting poor wireless signals when I'm standing right by the router. I downloaded a app on my iPhone where I can walk around my house and see the different strengths of the signal and the further away I get from the modem the stronger he gets. When I login to the 5 GHz network my speeds are between 60 and 80 and my cable modem plan is 100 so I would think I would be closer to 80 all the time especially when I'm in the same room as the router.
I hope you don't mind me asking a little bit of a different question, but it is still about the settings in Genie
- TheEtherJun 08, 2017Guru
What makes you think the signal gets stronger as you move farther away? Wi-Fi signal strength is often expressed in a unit called the dBm. For Wi-Fi signals, the value is always a negative number, so a larger value represent a weaker signal. For example, -70 dBm is weaker than -50 dBm.
Wi-Fi speeds will depend on many factors:
- Signal strength
- Congestion caused by nearby Wi-Fi networks operating on the same channel
- Interference caused by nearby Wi-Fi networks operating on nearby channels
- Interference caused by non-Wi-Fi devices, like microwave ovens, cordless telephones, baby monitors, Bluetooth devices, wireless speakers, etc.
- The Wi-Fi protocol supported by the device (802.11n, 802.11ac, etc.)
- The number of antennas in the device
Beyond that, speeds can also be affected by non-Wi-Fi factors:
- A bad connection to the Internet
- Congestion in the Internet
- Congestion on your Internet link caused by your other devices
- High CPU loads on the device and/or router
That's a long-winded way of saying that without more information, it's really impossible to say why you are getting 60 to 80 Mbps on your 100 Mbps plan. You should check whether a wired device can achieve speeds closer to 100 Mbps. If it doesn't, then chances are the problem is with the modem, your Internet connection or the Internet itself.
- eaglepiJun 08, 2017Guide
What info do you need to better help me?
You can start by testing the speed of a wired device.
Provide the data from your app. Signal levels, number of nearby Wi-Fi networks and what channels they are on. What channels you are using. The types of devices you have and their Wi-Fi capabilities. Whether you have eliminated any potential sources of interference.
