eaglepi
Jun 08, 2017Guide
I would appreciate some help to make sure that I have the proper security settings on my router
Hello, I currently have the NETGEAR AC1750 Dual Band WiFi Gigabit Router, when I originally bought it I set it up according to the instructions but now I'm wondering if I set it up properly. Course...
michaelkenward
Jun 09, 2017Guru - Experienced User
eaglepi wrote:Hello,
It probably doesn't matter, but AC1750 is not a router model. It is a wifi speed thing. Netgear makes several routers with that spec, including various versions of the R6400 and R6300.
- eaglepiJun 09, 2017Guide
if my router isn't a router why does it say it's a router and why does it work like a router??
The description is,
NETGEAR AC1750 Dual Band WiFi Gigabit Router (R6400)
- michaelkenwardJun 09, 2017Guru - Experienced User
eaglepi wrote:if my router isn't a router ...
No one said that. What I said was that "AC1750 is not a router model".
As you say, the description is:
The important bit is R6400. The AC1750 thing is misleading.
This is the first time that you have mentioned R6400. You may have said that when you posted your first message, but the bulletin board did not pass on this information.
Now we know what you are talking about.
OK Thanks and sorry for not putting the whole name of my router.
You posted 3 lines in grayed out text was that something you were telling me? if so what should I do withthat info. Please remember I am here to get help because I know litter about configing routers so I can read stuff and know what to do with it without some guideence.
Modem Router: D6400 (Firmware V1.0.0.58_1.0.58.chk)
Powerline:XWN5001, XAVB5101, XWNB5201, XAVB5421
WiFi: WN2000RPT, WNDA3100What does all the above mean????
Thanks
Ron
