iatrosm90's avatar
iatrosm90
Follower
Jan 09, 2016
identifying devices on my netwrok
network genie says i have 12 devices on my home network.  some are identified by a name, but many simply have a number.  How could i go about identifying and naming each device on my network.  things...
  • DexterJB's avatar
    DexterJB
    Nov 07, 2016
    Hi K8K and wendyb,
    One way to approach this is by checking the corresponding IP address assigned to device through the Network Map then checking the IP on the actual device. Another way is to do address reservation in order for the device to have a consistent IP address assigned to it by the router so that you can easily name the device through the Network Map. You can check the link below for the steps.
    http://kb.netgear.com/app/answers/detail/a_id/24091
    Dexter
    Community Team
