iatrosm90
Jan 09, 2016Follower
identifying devices on my netwrok
network genie says i have 12 devices on my home network. some are identified by a name, but many simply have a number. How could i go about identifying and naming each device on my network. things...
- Nov 07, 2016
One way to approach this is by checking the corresponding IP address assigned to device through the Network Map then checking the IP on the actual device. Another way is to do address reservation in order for the device to have a consistent IP address assigned to it by the router so that you can easily name the device through the Network Map. You can check the link below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/24091
Dexter
Community Team
wendyb
Nov 03, 2016Aspirant
i'm frustrated too. it's a simple enough question on any netgear router - how to map/determine devices that are shown only as mac or ip numbers. my solution: same as figuring out my electrical panel. I'm going to turn them off one by one and see which one disappears, then label. Any I can't find i will block. if i can't connect one of my phones later today, i'll know that the culprit.
DexterJB
Nov 07, 2016NETGEAR Moderator
Dexter
Community Team
