sekopp
Oct 10, 2022Aspirant
If I ever switch from router view to extender viwe, I cannot return to router view
I have an issue with the Nighthawk app. If I switch from the router view to the extender view, I CANNOT return to the router view without deleting cache and force stopping the app. Sometimes this doe...
Oct 10, 2022Guru - Experienced User
Do you not see Network Map while on the Extenders screen in the app?
Please post a screen capture if what you see on the router and extender screens on the app.
sekopp
Here are the screenshots for which you asked.
- FURRYe38Oct 10, 2022Guru - Experienced User
- sekoppOct 11, 2022Aspirant
Yes. I see the map in both views.
I am having issues dragging and dropping files or browsing and dropping files.
I am trying a different browser.
Here is the extender view.
It only allows one update per post...
- FURRYe38Oct 11, 2022Guru - Experienced User
What happens when you enter the EX page on the app, then close it then reopen it? Does it still connect to the EX or the router?
Selecting the host router causes this error to appear?
Can you use the 3 horizontal lines and then select the router from the product list seen here?
Are you using the NETWORK19 default SSID name on the host router?
I would recommend you submit a bug report to NG as well:
