wfault
Feb 06, 2023Aspirant
Install Armor Without Using an App on Mobile Device
How do I download/install Armor without using an app on a mobile device? I would like to try Armor with my NightHawk AX1800 router. However, I am unable to find anything that tells me how to get...
wfault
Thank you for clarifying about needing an app on a mobile device. Looks like I will not be able to give Armor a try.
Availability of devices is not an issue. The issue is they are not permitted to be connected to that particular network -- even though it is in my home. Our phones, tablets, and kids' PCs use a different network/different router/different ISP.
Thanks again for clarifying.
Feb 06, 2023Guru - Experienced User
So you can't temporarily connect something from the other network to and NG network and get something set up then afterwards, put the device back on the other network?
