dominic2005
Nov 02, 2016Aspirant
Internet blocking per device at specific times
Is there any way to block a device from access the internet at specific times? All I can find is a blanket block with 1 device allowed, however: I have 8 devices connected; 2 desktops, 2 phones...
- Nov 04, 2016
Hi dominic2005,
There is no specific feature on the router that can do this. However, you can setup address reservation for the devices then block all the services on a specific schedule. You can check the links below.
http://kb.netgear.com/app/answers/detail/a_id/24091
http://kb.netgear.com/app/answers/detail/a_id/24055
http://kb.netgear.com/app/answers/detail/a_id/24054
Dexter
Community Team
DexterJB
Nov 04, 2016NETGEAR Moderator
Hi dominic2005,
Dexter
Community Team
dominic2005
Nov 04, 2016Aspirant
Hiya.
Thanks. I have just tried all that, not sure where I went wrong but it had zero affect.
- DexterJBNov 07, 2016NETGEAR Moderator
Hi dominic2005,
1. Were you able to successfully do the address reservation?
2. Were you then able to set the schedule you want some devices to not be able to go online?
3. Were you able to set the Block Services feature to "ALL" for the devices on the specific IP address range?
Dexter
Community Team
- dominic2005Nov 07, 2016Aspirant
Hiya.
My apologies for not confirming this as solved, but yes, eventually I was able to get it to work. I had a few problems getting the other PC to actually not still have internet access, but I found simply turning the router off for a few moments and back on seemed to sort it.
Well...I assume it has, I've never stayed up late enough to verify it, but it worked when I did some tests at the time I was setting it all up, so assume it is all ok.
Thanks- DexterJBNov 08, 2016NETGEAR Moderator
