pko
Sep 20, 2013Novice
iOS 7 breaks Genie Airprint
Using latest Genie (2.2.28.24) and WNDR4500 firmware (V1.0.1.36_1.0.6.3), I was able to print easily from my iPhone5 with iOS 6. After upgrading to iOS 7, Genie's Airprint feature no longer works wit...
Devor
Sep 21, 2013Luminary
Although I don't know that much about Apple stuff and it could be like you said a compatibility issue with IOS 7. If you haven't rolled back to an earlier version of Genie, you could try the solution found here. Read to the bottom of the thread.
Otherwise, like June mentioned, submit a ticket here.
