pko
Sep 20, 2013Novice
iOS 7 breaks Genie Airprint
Using latest Genie (2.2.28.24) and WNDR4500 firmware (V1.0.1.36_1.0.6.3), I was able to print easily from my iPhone5 with iOS 6. After upgrading to iOS 7, Genie's Airprint feature no longer works wit...
pko
Sep 21, 2013Novice
FYI, Genie's Airprint feature works perfectly with a Canon MX880 WIRELESSLY, not needing USB, when using iOS 5 or 6 with iPad or iPhone. Still does. Only doesn't work with an iPhone that was upgraded to iOS 7. Yes, iOS 7 caused the problem...BUT, Netgear should update Genie to be compatible with iOS 7. No doubt they will, sooner or later.
Genie's Airprint feature is truly a terrific thing, turning our almost new but non-Airprint printers into Airprint-enabled devices. I have tried many apps to do this, none of which were reliable, and many of which didn't work at all. Genie's Airprint worked perfectly and transparently, and still does if we use devices running iOS 6 or 5. Why does everybody get so huffy when all I ask is that Netgear update Genie so the Airprint feature works with iOS 7 devices?
