pko
Sep 20, 2013Novice
iOS 7 breaks Genie Airprint
Using latest Genie (2.2.28.24) and WNDR4500 firmware (V1.0.1.36_1.0.6.3), I was able to print easily from my iPhone5 with iOS 6. After upgrading to iOS 7, Genie's Airprint feature no longer works wit...
shadowsports
Sep 22, 2013Hero
You can rollback an iPhone to any previously supported OS... but who would want to. Loss of features and apps functionality = headache. A lot of the newer apps are not supported in previous versions. Unless you have an apps archive it's not worth it.
Jim769 wrote: Once iOS 7 is installed there is no way to go back your stuck. :rolleyes:
