pko
Sep 20, 2013Novice
iOS 7 breaks Genie Airprint
Using latest Genie (2.2.28.24) and WNDR4500 firmware (V1.0.1.36_1.0.6.3), I was able to print easily from my iPhone5 with iOS 6. After upgrading to iOS 7, Genie's Airprint feature no longer works wit...
gamtu
Nov 11, 2013Tutor
This EXACT same issue happened when iOS 6 rolled out. iOS 5 and earlier would print using Netgear Genie but a new iPhone 5 (iOS 6) would not print. People who updated their older phones and iPads to iOS 6 couldn't print using Netgear Genie either. Netgear dragged their back sides on getting a patch made. I suspect they'll drag them again updating Genie for iOS 7. Since Netgear advertises their routers will allow any iOS device to print to ANY printer regardless of whether or not the printer is an airprint printer, its up to Netgear to get off their duff and patch their Genie software when Apple comes out with a new version of iOS.
Netgear Email support is useless. I would consider Netgear Email support a complete and total embarrassment if I were Netgear. They should just close their Email support center and stop offering that support option since your no better off after contacting Netgear Email support.
