pko
Sep 20, 2013Novice
iOS 7 breaks Genie Airprint
Using latest Genie (2.2.28.24) and WNDR4500 firmware (V1.0.1.36_1.0.6.3), I was able to print easily from my iPhone5 with iOS 6. After upgrading to iOS 7, Genie's Airprint feature no longer works wit...
gamtu
Nov 12, 2013Tutor
BillPark wrote: .
I just updated my iPad with the new release V 1.0.0.36, but it did not fix the problem.
I know with iPhone you do not have to have the genie app on the phone. I'm not 100% positive but I'd assume the same is true with iPad. You don't need the app on your device you only need the genie software on your computer. That computer has to be connected to your network, turned on for the Airprint conversion to work.
