pko
Sep 20, 2013Novice
iOS 7 breaks Genie Airprint
Using latest Genie (2.2.28.24) and WNDR4500 firmware (V1.0.1.36_1.0.6.3), I was able to print easily from my iPhone5 with iOS 6. After upgrading to iOS 7, Genie's Airprint feature no longer works wit...
bond_vigilante
Dec 22, 2013Aspirant
Hello,
I'm running Windows 8. I've had an N900 router for awhile but just now hooked up the printer to use ReadyShare print on a (non-AirPrint compatible) Dell 2155cdn color laser printer. All of my iOS devices have been upgraded to iOS7 before trying to use ReadyShare.
I have the NETGEAR USB control center/media extender version 1.32 (driver version 1.74.27) installed on my Windows 8 machine (that has the N900 plugged into it).
I have NETGEAR Genie version 2.3.1.16 installed (though I don't think that being installed is necessary for ReadyShare print).
My issue/question: I've never used ReadyShare Print before. When I went to try to print, it shows NO printers are installed. Is that the result that is expected with this issue - or do I have another problem?
Thanks for your help! I did submit a trouble ticket to Netgear saying I can't get it to print on iOS7.
Thanks
Thanks
