R9
Feb 12, 2017Aspirant
iOS Genie app revamp
Does Netgear have any plans to update the Genie app UI and functionalities? The current UI is reminiscent of the 80s and is way too bland not to mention the limited functionalities accessible through...
michaelkenward
Feb 12, 2017Guru - Experienced User
Which Netgear genie app do you have in mind? Browser, Windows standalone, Android, iOS? Netgear calls them all genies.
- R9Feb 12, 2017Aspirant
Its already mentioned in the title - iOS.
- michaelkenwardFeb 12, 2017Guru - Experienced User
Ah. The usual problem. Reader fails to read headline.
That's why it usually helps to repeat the salient information in the body text, for the benefit of thick readers.
Appreciate the advice, will definitely help all the thick posters.
