R9
Feb 12, 2017Aspirant
iOS Genie app revamp
Does Netgear have any plans to update the Genie app UI and functionalities? The current UI is reminiscent of the 80s and is way too bland not to mention the limited functionalities accessible through...
michaelkenward
Feb 12, 2017Guru - Experienced User
Ah. The usual problem. Reader fails to read headline.
That's why it usually helps to repeat the salient information in the body text, for the benefit of thick readers.
R9
Appreciate the advice, will definitely help all the thick posters.
- William10aFeb 14, 2017Master
All versions of Genie need a face lift from the ground up the design is old in many ways and the lay out of functions is workable but could use some changes as well.
I know that is hard to design a graphics lay out for every display screen even the same web plag is display with small differences on web browsers, monitors, and phone displays colors can change a little or the look may off a little.
- aalexandrebetaFeb 15, 2017Master
William10a Netgear Genie is a terrible mess and need to be urgently reworked and dealt with special care, whatever OS or type of device you are running on!!
