BigTy's avatar
BigTy
Guide
Sep 25, 2020
iOS14: Can't connect to Router
Good morning:
Since my update to iOS 14 on my phone, I'm unable to connect to the router via the app. I can only get connected with ViewAnywhere. I have attempted restarting the modem, restarting my phone, deleting and reinstalling the app... all to no avail.
I have local networking turned on as well.
I also have an Orbi network, went thru the same process with the same results. The difference here is, in the Orbi settings, there is NO OPTION to connect to the local network.
Has anybody had any success fixing this or can provide any insight?
Thank you in advance!
    • BigTy's avatar
      BigTy
      Guide
      Hi Christian,
      Thanks for your response. Unfortunately that Doesn’t help for my Orbi or Nighthawk apps.
      The option for the local network slider isn’t there at all for my Orbi app and it’s already turned on for the Nighthawk app.
      I’ve deleted and reinstalled both apps a number of times. My networks are still running fine, but I can only access them thru connect anywhere.
      It’s really frustrating 🤷🏽‍♂️
      • DDDT's avatar
        DDDT
        Exactly the issue I have. Did everything as instructed but keeps failing to connect.
  • I had to go to the iPhone general settings and reset the network settings.  Then, under general settings, scroll down to find the VPN setting.  Under that tab, I had to select the web protection (armor) that was being used and turn off the "Connect on Demand" by sliding the button to disable it.
    For some reason, when "Connect on Demand" is on, my phone disconnects from the WiFi network and makes it impossible to sign in to the Nighthawk App, but when I disable it, the phone connects immediately to the app.
    Hope it works for you.
  • You may also need to update the app to let it compatible with the iPhone system. If no change, you can use an repair tool like TunesKit to turn iPhone back to normal. Or try to contact app server.
