mburke5's avatar
mburke5
iPad Netgear app "Save to Readycloud" gives a list of folders to save to, how to clear list?
iPad Netgear Readycloud app offers "Save to Readycloud" and then gives a list of folders to save to, how to clear list?
  • mburke5's avatar
    mburke5
    Jun 29, 2019
        Hey thanx again for reply.
        I did it (cleared SaveTo list) by uninstalling the app, which wiped data on iPad and then reinstalled with clean slate of saveto folders to work with.
         Thought I would tell you all in case another asks same question in future.
         Also, I did not ever read reviews, and many people have commented on the apps “simplicity” at the Apple app site.
         Take care, Mark
    • mburke5's avatar
      mburke5
       Thanx for reply, no these folders are in use. They are parent and child folders, sub-folders, etc, that I save various items to.
      The list of “save to” folders is simply growing too large, I was hoping to clear it, that’s all.
      thanks again.
      For clarity, on iPad, when desiring to save a .pdf file, for example, to my attached hard drive on Nighthawk Router, I open pdf, find the iPad multifunction button (a square with arrow pointing up from top of square) - and then searching through my options I find Netgear ReadyCloud app, click it and am presented with ability to locate a folder within my Netgear network to save to.
      Folder list grown large, with no way to edit list or clear it.
    • mburke5's avatar
      mburke5
      Thanx again, I just thought to uninstall the app and reinstall might help. ~Mark
      • michaelkenward's avatar
        michaelkenward
        Sounds like the iPad is remembering things.
        Any way of wiping its memory for that sort of stuff?
