ImaMember
Dec 30, 2020Aspirant
iPhone NetGear NightHawk App Login Problems
Login works, but is problematic. I have the iPhone app for NetGear Nighthawk and I'm using the same iPhone as always. But lately the app tells me it doesn't recognize the device, despite it being t...
Christian_R
Jan 05, 2021NETGEAR Employee Retired
Hello ImaMember,
May you reinstall the Nighthawk app and let me know if your issue persists.
Christian
- ImaMemberJan 07, 2021Aspirant
I removed the app and re-installed the app and it still gives the same symptoms I described in the original problem.
