jhizzle
Apr 28, 2022Follower
Issue with connecting to Nighthawk App
Recently I've been unable to log into the Blackhawk App on my iPhone 11 Pro (iOS 15.1) because it said that I needed to turn off my VPN. I logged into my Blackhawk R6400v2 from my laptop, which I ha...
michaelkenward
Apr 28, 2022Guru - Experienced User
Which version of the Nighthawk (I assume) app?
Now that the VPN is off, the App tells me that the "Router Not Found". Go to Settings > and join you router's WiFi Network
What is the modem/gateway in front of the router?
What version of firmware is in the R6400v2?
By the way, this isn't a Nighthawk router, just a standard wifi router usually discussed here:
General WiFi Routers (Non-Nighthawk & Non-Orbi) - NETGEAR Communities
For apps, there is yet another section:
Nighthawk App - NETGEAR Communities
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
Make sure you have icloud relay disabled.
Also disable random mac/ip on the device with the nighthhawk app.
I've seen those cause issues with using the app
