name99
Oct 23, 2019Guide
length of name of attached devices
Can Netgear PLEASE allow us to use names for attached devices that are long than 15 characters? 15 characters is, frankly, amateur hour. As is forced capitalizing all the names that you were able to acquire off the network.
We are not living in 1992 anymore. Bit are cheap, bytes are cheap, kilobytes are cheap. Have some pride in your work -- and that includes understanding how people want to use your products, which means rich names strings like "Netatmo Sensor - Upstairs Bedroom".
Fing, for example, as a company that's in the same sort of space, but that understands how UI works in the 21st century, doesn't have these idiotic limitations.
Not impressed about the Netgear UI and the limited name lengths, and some attempts to "niceify" things, too. In a light attempt for defense of Netgear - and different from eg. Fing - Netgear does support and use the Web UI and Apps (Genie, Nighthawk, Orbi) on many different products. Needless to say, they failed to change the 1990ties specs on the migration from the Genie to the Nighthawk/Orbi environment - not only where it comes to the allowed length of the device names/description text fields.
Where are you looking?
I have longer device names visible in the Netgear Windows app and in the browser graphical user interface (GUI).
That is with a different router. But there is clearly no theoretical limit.
I also see no forced capitals.
Nighthawk App and e.g. the R9000 device names are limied to 32 chars, and no change in the first characger from lower to uppercase (as on the gaming routers.
Nighthawk App and e.g. the R9000 device names are limited to 32 chars, and no change in the first character of the string from lower to uppercase (as on the RAXnnn).
ChristineT we still can't edit posts in this community section ...
- JoseAndres041Luminary
Why do you need a long device name? Sorry, i just don't know why I'd like to have a long device name. I want things simple but if you can give me a nice reason then maybe I'd try that.
- name99Guide
I gave you an example in the first post. And I am not making these up, I just wanted to copy the names from my Fingbox.
So for example, NetAtmo sensor (Upstairs Bedroom)
33 characters, and every one of them makes sense.
If you're living in an IoT world (which apparently Netgear is not) you will have LOTS of names like this. At least one longish part to identify the device type, another longish part to identify the location.
