Aaviles769
Jun 22, 2016Aspirant
Linux 17 and netgear wnd3100 usb
I just built a Linux 17 box and am using a Netgear wnda3100 usb wifi adapter. Everytime i try to cnnect to my wifi which is a netgear genie; it prompts me for a password. I put in the correct wifi pas...
DexterJB
Jun 25, 2016NETGEAR Moderator
Hi Aaviles769,
1. Have you tried changing the wireless password of your network?
2. Have you tried changing the security mode (WPA/WPA2)?
3. Have you tried disabling the WiFi password for your network for isolation purposes?
4. Are there other wireless devices in your network that can connect to your router?
Dexter
Community Team
