Aaviles769
Jun 22, 2016Aspirant
Linux 17 and netgear wnd3100 usb
I just built a Linux 17 box and am using a Netgear wnda3100 usb wifi adapter. Everytime i try to cnnect to my wifi which is a netgear genie; it prompts me for a password. I put in the correct wifi pas...
DexterJB
Jun 28, 2016NETGEAR Moderator
Hi Aaviles769,
I would like to do a follow and check if you are still experiencing the issue.
Dexter
Community Team
- Aaviles769Jun 28, 2016Aspirant
Thanks Dexter for your follow up. But still having the issue. I reset my NETGEAR GENIE WIFI Router and setup a NEW SSID name and WPA password and still no issues. There MUST Be some incompatibility with my Linux 17 OS and using a NETGEAR WNDA3100 USB wifi adapter becuase it DOES CONNECT TO MY NEIGHBORS WIFI and they are using Centurylink Prism. The USB Wifif adater is fine meaning that I have used is usccessfully on my wifi network when used witha Windows 10 PC so I know the adapter is good.
On my newly built Linux 17 PC, it see my wifi network and prompts for a password, I enter it correctly and it goes away and then prompts me again. weird
I will try to setup my wifi router with NO SECURITY and see If I can connect
- DexterJBJun 29, 2016NETGEAR Moderator
Hi Aaviles769,
Thank you for the update. Please keep us posted on the results.
Dexter
Community Team
