R7800HelpMe
Oct 17, 2023Aspirant
Logging into the Admin settings on a web browser
I try logging into the admin settings through a web browser. It takes me to my password recovery. I enter what my answers are for the security questions, and for split second, it converts my answers ...
R7800HelpMe
Factory reset again? That doesn't explain why my answers get changed to numbers, letters, and symbols. I type them in and they are find, hit continue and they change just before going to the next screen. If I perform a factory reset, is that going to cause issues of forget all my devices I have connected to my router? I just did a factory reset about 3 weeks ago. Am I going to have to do this every time I want to log in through a web browser?
michaelkenward
Oct 17, 2023Guru - Experienced User
Reset it and you erase any answers that you may have provided earlier on. You are back to the defaults.
Disable password recovery and that won't happen. Just find a way to remember the password you provided.
This is local access on your own network. So you probably don't need a heavy duty password.
