R7800HelpMe
Oct 17, 2023Aspirant
Logging into the Admin settings on a web browser
I try logging into the admin settings through a web browser. It takes me to my password recovery. I enter what my answers are for the security questions, and for split second, it converts my answers ...
michaelkenward
Oct 17, 2023Guru - Experienced User
R7800HelpMe wrote:
I enter what my answers are for the security questions...
Are they answers that you completed, or are you just answering questions that come up?
If you are trying to use the "password recovery" option, there is a bug in Netgear's implementation of password recovery on some devices. You can get locked into a closed loop.
If password recovery is enabled, but you have not set the answers to the questions, it keeps sending you back to the beginning of the process. If you haven't already given the thing your personal answers, they are not in its memory and it has no way of knowing if they are correct.
If the standard factory password (password) does not work, then you will have to factory reset the thing to get back to that. Then either disable password recovery (check the manual for your device) or provide some answers to those questions.
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
R7800HelpMe
They are answers I thought I had completed the last time I did a factory reset. Yes, it seems I am in a loop.
- michaelkenwardOct 17, 2023Guru - Experienced User
Hmmm.
What are we to make of that?
- R7800HelpMeOct 17, 2023Aspirant
I entered them last time.
- FURRYe38Oct 18, 2023Guru - Experienced User
Can you try this?
