bano91's avatar
bano91
Tutor
Sep 27, 2024
Login Denied on Nighthawk App
I just got a new Samsung S24+ (Model SM-S926U, Hardware version REV1.0, Android 14) and am signing into all of the apps. I went to sign into the NETGEAR Nighthawk WiFi Router app (Version 2.40.0.4040...
  • bano91's avatar
    bano91
    Sep 28, 2024
    I did what you suggested, but it didn't like my password for the router so I couldn't reset. In one last attempt, what I ended up doing was asking for the one time temporary password that Netgear will email to you to try to access the app. I'm 100% certain I was using the correct one before... That let me into the app, kinda, because for some strange reason, the app requested that I do what you essentially described, which was to do the reset, before I could use the app. This time it liked the password, so I reset it to the exact same password and I was in the app fine! I logged back out, used what I knew was my password, and it let me in fine on the new phone... Just in case this happens again, I believe I could go to "192.168.0.1" in a browser and use the Netgear Genie to get back into the router as long as the phone is already connected to the WiFi. Thank you for your help.
