bano91
Sep 27, 2024Tutor
Login Denied on Nighthawk App
I just got a new Samsung S24+ (Model SM-S926U, Hardware version REV1.0, Android 14) and am signing into all of the apps. I went to sign into the NETGEAR Nighthawk WiFi Router app (Version 2.40.0.4040...
- Sep 28, 2024I did what you suggested, but it didn't like my password for the router so I couldn't reset. In one last attempt, what I ended up doing was asking for the one time temporary password that Netgear will email to you to try to access the app. I'm 100% certain I was using the correct one before... That let me into the app, kinda, because for some strange reason, the app requested that I do what you essentially described, which was to do the reset, before I could use the app. This time it liked the password, so I reset it to the exact same password and I was in the app fine! I logged back out, used what I knew was my password, and it let me in fine on the new phone... Just in case this happens again, I believe I could go to "192.168.0.1" in a browser and use the Netgear Genie to get back into the router as long as the phone is already connected to the WiFi. Thank you for your help.
bano91
Sep 27, 2024Tutor
Thank you FURRYe38.
Out of hope, I simply tried disabling MAC Address randomizers on my phone and tried to log on again to no avail, same result.
I can't rest the router right now, but that looks like the next route.
There should be better solution. I get Netgear is a hardware/firmware company, and really liked their stuff, but I'm beyond tired of their software...
Sep 27, 2024Guru - Experienced User
Hopefully the reset process will work.
- bano91Sep 28, 2024TutorI did what you suggested, but it didn't like my password for the router so I couldn't reset. In one last attempt, what I ended up doing was asking for the one time temporary password that Netgear will email to you to try to access the app. I'm 100% certain I was using the correct one before... That let me into the app, kinda, because for some strange reason, the app requested that I do what you essentially described, which was to do the reset, before I could use the app. This time it liked the password, so I reset it to the exact same password and I was in the app fine! I logged back out, used what I knew was my password, and it let me in fine on the new phone... Just in case this happens again, I believe I could go to "192.168.0.1" in a browser and use the Netgear Genie to get back into the router as long as the phone is already connected to the WiFi. Thank you for your help.
- FURRYe38Sep 30, 2024Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
